TR-DOS command LIST allocate block of zx ram for read sectors with directory. After end of LIST command must TR-DOS release allocated ram and return.
LIST command work correct only if is used in basic line: RANDOMIZE USR 15619:REM:LIST
but LIST from TR-DOS command line not release allocated memory before return.Each LIST from command line allocate next ram and if ramtop is low then can allocate all free zx memory and show OUT OF RAM message. RETURN command realease all allocated memory.
See video example of TR-DOS 5.03
Czech version of TR-DOS 5.05(cz) use fixed code of command LIST. Allocated ram is always released at end of LIST command.
Exist any other TR-DOS versions with fixed this bug ?![]()
Ответить с цитированием
