Страница 11 из 26 ПерваяПервая ... 789101112131415 ... ПоследняяПоследняя
Показано с 101 по 110 из 251
Тема: ScorpEvo (Scorpion ZS на базе ZX-Evolution)
  1. #101
    Praha
    34
    15 сообщений
    Цитата Сообщение от БК-0010 Посмотреть сообщение
    Вот сравнительная раскладка рекомендуемая к использованию программистами для Пента4Мб и Скорпо-Кая4Мб:
    |Pent|S-KAY|
    |A19’ |A21’ |D5 #7FFD
    |A18’ |A20’ |D6 #7FFD
    |A17’ |A17’ |D7 #7FFD
    |A20’ |A18’ |D4 #1FFD
    |A21’ |A19’ |D7 #1FFD
    = chaotic memory pages layout. Best way is add one port for switching memory paging = better compatibiity with original software.
    I use in my PROFI interface this feature:
    Memory paging (ZX clone type) is selectable via OUT 495,x or in menu. Position of logical ram pages 0-63(1MB ram) are same in all ZX modes.
  2. #102
    S.Pb
    Yes, it is a Russian tradition!
    |S256|Kay |P512|Pv2.2|P4Mb|S-Kay4Mb|
    | _-_ | _-_ | _-_ |A17’ |A19’ |A21’ |D5 #7FFD
    | _-_ | _-_ |A17’ |A18’ |A18’ |A20’ |D6 #7FFD
    | _-_ |A19’ |A18’ |A19’ |A17’ |A17’ |D7 #7FFD
    |A17’ |A17’ | _-_ | _-_ |A20’ |A18’ |D4 #1FFD
    | _-_ |A18’ | _-_ | _-_ |A21’ |A19’ |D7 #1FFD
  3. #103
    Praha
    34
    15 сообщений
    Exist any software with support KAY or P4MB memory ?
    I know only TR-DOS with ramdisc for KAY 1MB memory.
  4. #104
    S.Pb
    This is not the best way. Software compatibility when using modified memory drivers exceeds 100%
    ---------- Post added at 17:53 ---------- Previous post was at 17:44 ----------
    For KAY - ISDOS, TR-DOS, and many other system programs that use the RAM disk.
  5. #105
    Praha
    34
    15 сообщений
    Theoretically is absolutly unnecessary support paging bits from other ZX clones. As I know all software with extended memory support is designed for Pentagon 256/512/1024.
    Only some games use scorpion 256kB memory. And CP/M support scorpion allram mode. Other clones are without good software support.
  6. #106
    S.Pb
    Yes, the smaller variety - so it better! So KAY and Scorpion are united in the standard SKAY-1Mb. Pentagon-1Mb and SKAY-1Mb merged into standards SKAY-4Mb and the Pentagon-4Mb, which are actually a single standard system memory management.
    ---------- Post added at 18:31 ---------- Previous post was at 18:19 ----------
    No, not true! Most software uses the drivers of all clones.
    ---------- Post added at 18:41 ---------- Previous post was at 18:31 ----------
    KAY, Scorpion, Pentagon, Profi - a clone of ZX Spectrum, mass produced. We can not abandon their support and development.
  7. #106
  8. #107
    55 сообщений
    Короче, дело к ночи.
    Да будет так:
    Scorpion-4096 memory_manager={p7ffd[7:6],p1ffd[7:6],p1ffd[4],p7ffd[2:0]}.
  9. #108
    Praha
    34
    15 сообщений
    ZX clones based on paging via D6,D7 on port #7FFD are problematic wit some software:
    http://zx.pk.ru/showthread.php?t=122...28%23FD%29%2CA
    For play original software for ZX128 must be PENTEVO/SCORPEVO switch to 128kB mode (must ignore paging bits D6,D7,D5 on port 7FFD and disable access to port #1FFD).
    Ideal paging for extra memory use ZX PROFI for example. Port #7FFD use paging bits D0-D2 as original ZX128 and additional port #DFFD with next paging bits at D0-D2. Only software support for PROFI memory is not so good as for Pentagons.
    Port #EFF7 on Pentevo can active allram mode (ram page 0 instead rom). Port #1FFD on Scorpevo also active allram. Scorpevo combine both ports for allram activation ?
    What about active turbo 7MHz on port #EFF7 and via read ports #7FFD and #1FFD ? Both ports is used in SCORPEVO ? If SCORPEVO is switched to 128kB mode (on port #EFF7) then turbo activation via read port #7FFD is always enabled ?
    Последний раз редактировалось VELESOFT; 08.08.2010 в 14:30.
  10. #109
    55 сообщений
    No, ScorpEvo don't have eff7 port. AllRAM mode activated with bit 0 of 1ffd port (as original Scorpion).
    No reading ports 1ffd & 7ffd only.
    ScorpEvo don't have 128kb mode, so far as don't have eff7
    ---------- Post added at 14:51 ---------- Previous post was at 14:46 ----------
    БК, PentEvo не содержит порта 1FFD Я его добалял для режима Скорпиона.
    ---------- Post added at 14:56 ---------- Previous post was at 14:51 ----------
    PentEvo page mapping:
    ( {2'd0,p7ffd[7:5],p7ffd[2:0]} )
    from source code
  11. #110
    S.Pb
    Полностью с Вами согласен
    ---------- Post added at 23:32 ---------- Previous post was at 23:24 ----------
    наплевать на то, что содержит, или не содержит PentEvo. PentEvo - это всего лишь шаблон, а не икона. Что нужно - то и будет содержать
  1. Pentevo/ZX Evolution - сборка и наладка
    от Ewgeny7 в разделе ZXEvo
    Ответов: 1267
    Последнее: 28.01.2025, 08:14
  2. Игровые автоматы на базе ZX
    от F0lken в разделе Разный софт
    Последнее: 22.05.2010, 22:24
  3. Pentevo/ZX Evolution revision A - тестинг
    от AAA в разделе ZXEvo
    Ответов: 354
    Последнее: 25.03.2010, 23:45
  4. Компьютер на базе Sega MD
    от Phenix в разделе SEGA
    Ответов: 26
    Последнее: 06.05.2008, 21:46
  5. Компьютер на базе Sega MD
    от Phenix в разделе Несортированное железо
    Последнее: 10.04.2005, 13:59
