Страница 11 из 25 ПерваяПервая ... 789101112131415 ... ПоследняяПоследняя
Показано с 101 по 110 из 245
Тема: Игровая приставка на К145ИК17
  1. #101
    Miskolc, Hungary
    Hello Everybody!
    First of all, I'm sorry, maybe it's a little bit off topic, but I can't speak (and read) Your language.
    I would like to ask some help.
    I have an old russian video game, called "Turnir." (I attached a photo.) I bought it some weeks ago, but unfortunately it has some problem(s). I would like to repair it, but I have no information about this game. I've spent so many time searching and searching, but no success.
    I found this:
    http://msk.molotok.ru/item1351907661...gr_turnir.html
    But without Russian knowledge I can't register there and ask the seller to scan the documents and upload somewhere.
    Is there anybody here who could scan a circuit diagram and/or a user manual and upload somewhere, please? I would be very happy. Thank You very much in advance!
  2. #102
    Магнитогорск
    96
    46 сообщений
    Petya, Write better what is the problem, and make a photo card (both sides) to the inscriptions on the chips could be seen, then we can find the appropriate version of schema
  3. #103
    Miskolc, Hungary
    The problem: no picture and no sound. There is only one sign of life: when I turn on the video game, the screen of the tv turns black.
    I attached some more photos. As You can see the IC is AY-3-8500-7.
    There is a part of the modulator, we don't understand. I marked it with a red circle on photo #3 and #4. On the photo #4 You can see it better, that the 2 cables are connected to each other and we don't know why? The more interesting is, that it seems to be original, because the soldered parts are marked with that green substance.
    If You need more/bigger photos, I can upload somewhere.
ID:	24620   Нажмите на изображение для увеличения.
ID:	24621   Нажмите на изображение для увеличения.
ID:	24622   Нажмите на изображение для увеличения.
  4. #104
    Магнитогорск
    96
    46 сообщений
    You can use as basis for the most similar scheme to К145ИК17 (look here: http://byte01.narod.ru/ik17.htm)
    The main difference between IC К145ИК17 from AY-3-8500 is used in К145ИК17 entry to choose the game with one button (when you click on it the game are changing in sequence), and the AY-3-8500 - six separate outputs for connecting rotary switches, which turn and will select the game (or multibutton switch with a dependent fixation). On this basis we can conclude that one of the earliest Soviet consoles - "Турнир", which appeared in 1978, probably is not installed chip К145ИК17 and AY-3-8500, as the game it is chosen such that multibutton switch (with four instead of six positions, as fotopistolet in "Турнир" is missing).
    Table with the findings for the AY-3-8500 is here: http://en.wikipedia.org/wiki/AY-3-8500
    And the fact that there is a black background means that the modulator (box closed metals) works.
    Check the signals on the chip itself AY-3-8500, may not be running master oscillator. and if possible connect the console to the low-frequency input.
    Последний раз редактировалось Ramiros; 31.01.2011 в 14:50.
  5. #105
    Череповец,Вологодская обл.
    Ну вот я и собрал окончательно свой Pong.Осталось только подписать кнопки и сделать подсветку (пока нет под рукой синих светодиодов).Что скажете?
    AMIGA 500 +512к memory card with RTC
    Ленинград-1 48к украшает стену в комнате.
    Compact 256 Turbo fdd 3.5' +Turbo ВГ +PAL кодер (NedoPC).
    Profi 3.2 почти воcстал из Ада. Ждет новые платы.
    Dendy Junior (Famicom клон).
    Видеоспорт5 (на К145ИК17) пылится в шкафу
    Магнитогорск
    96
    46 сообщений
    RST 0, Нормально если бы кнопки однотипные, было бы симпатичней.
  7. #106
  8. #107
    Miskolc, Hungary
    Ramiros, thank You very much for Your fast and kind help!
    Цитата Сообщение от Ramiros Посмотреть сообщение
    ...if possible connect the console to the low-frequency input.
    If I think well, does it mean that I need an old tv? You know, I have another old console, a Conic TVG-101 (Made in 1977). That machine works, but I can't fix the screen on my tv. The screen jumps vertically very fast. So I decided to buy a contemporary tv (a Junoszty, or a hungarian made) to test these old games, because I'm not sure that today's televisions are suitable for it.
    Can I ask what is Your opinion about the fourth picture? Do You think it is normal that the two cables (in the red circle) are connected to each other?
  9. #108
    Магнитогорск
    96
    46 сообщений
    In the photo hard to see what was on the loop, but if it is short-circuiting, then clearly, this is not normal and the TV did not show, try to remove it.
    I hope you know that the prefix should be connected to TV antenna input and to scan the channels to find the channel where it should show?
    By the way, modern TVs do not have problems with attachments on К145ИК17.
  10. #109
    Miskolc, Hungary
    Yes, I know it and I tried the console(s) that way. Hmm... I think, I will buy an old russian or hungarian tv for sure. Those are very cheap, nearly free.
    By the way, I have good news: one of Your member, Panther scanned and sent me a user manual and circuit diagrams. I would like to say Him a very very big thank You! I think by the documents We'll be able to repair this old console.
    And of course, thank You once again for Your help!
    Maybe my next comment will be about a working Turnir.
  11. #110
    г. Пермь
    Petya, hi, could not you lay out the schema, which one to you has given Panther. It is interesting to look is simple.
    For certain in an attachment it is necessary to interchange all electrolytic capacitors, and as to test for serviceability of remaining parts - microcircuits and other. That the attachment has earned. A thank.
    Последний раз редактировалось Dragoos; 01.02.2011 в 09:07.
  1. Игровая приствка Wii?
    от AAA в разделе Nintendo
    Ответов: 85
    Последнее: 18.04.2022, 23:46
  2. Fuzebox - полностью открытая 8-битная игровая приставка
    от CityAceE в разделе Зарубежные компьютеры
    Ответов: 22
    Последнее: 09.03.2017, 15:35
  3. неизвестная приставка
    Ответов: 22
    Последнее: 19.01.2009, 22:27
  4. Есть комп ... или приставка ...
    от Zerios в разделе Зарубежные компьютеры
    Последнее: 10.06.2008, 20:09
  5. Куплю К145ИК17 или ее аналог AY-3-8500
    от Retrograd в разделе Барахолка (архив)
    Последнее: 24.12.2007, 16:32
