Показано с 1 по 10 из 287
Тема: ПК8000 - Контроллер дисковода
    Ukraine
    Цитата Сообщение от DemonId7 Посмотреть сообщение
    А что за формат файла у прошивки РТ2? Как его перевести в бинарник, для заливки в 27C512?
    Там табличка типа такой:
           *  Контpоллеp FDD HD/DD. Веpсии от 02.07.01/05.07.01 Автор MVV  *
           |       |                   Конъюнктор                          |
           | Вход  |-------------------------------------------------------|
           |       |   1-8	 |  9-16  | 17-24  | 25-32  | 33-40  | 41-48   |
    A0B    |  A1   | 11...... 11****** ******** ******** ******** ******** |
    A1B    |  A2   | 11...... 11****** ******** ******** ******** ******** |
    A9B    |  A3   | ..0..... ..****** ******** ******** ******** ******** |
    A8B    |  A4   | ..1..... ..****** ******** ******** ******** ******** |
    A10B   |  A5   | ..1..... ..****** ******** ******** ******** ******** |
    A11B   |  A6   | ..1..... ..****** ******** ******** ******** ******** |
    A12B   |  A7   | ..1..... ..****** ******** ******** ******** ******** |
    A13B   |  A8   | ..1..... ..****** ******** ******** ******** ******** |
    A15B   |  A9   | ..00110. ..****** ******** ******** ******** ******** |
    A14B   |  A10  | ..00101. ..****** ******** ******** ******** ******** |
    MREQB# |  A11  | ..0.000. ..****** ******** ******** ******** ******** |
    M1B#   |  A12  | ..0.000. ..****** ******** ******** ******** ******** |
    IORQB# |  A13  | 00.....0 00****** ******** ******** ******** ******** |
    DOSON# |  A14  | 00.0...1 00****** ******** ******** ******** ******** |
    WRB#   |  A15  | 01...... 01****** ******** ******** ******** ******** |
    A7B    |  A16  | 00...... 11****** ******** ******** ******** ******** |
           | Выход |                                                       |
    S#     |  ^Y1  | ----AAA- --AAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA |
    I/O#   |  ^Y2  | -------A --AAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA |
    R#     |  ^Y3  | --A----- --AAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA |
    SELDOS#|  ^Y4  | ---A---- --AAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA |
    CSВГ#  |  ^Y5  | AA------ --AAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA |
    FFWR   |   Y6  | -------- A-AAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA |
    FFRD#  |  ^Y7  | -------- -AAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA |
    EOB#   |  ^Y8  | -A------ --AAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA |
      Примечания :
         *	 в конъюнкцию входит прямое и инверсное значение переменной
         .	 переменная не входит в конъюнкцию
         0	 в конъюнкцию входит инверсное значение переменной
         1	 в конъюнкцию входит прямое значение переменной
         -	 конъюнктор отсутсвует в функции
         A	 конъюнктор присутсвует в функции
         ^   функция имеет активный низкий уровень
    Если менять на 27C512, то нужен ли буферный регистр на выходе?
    Да, так как во время формирования адреса и переходных процессов в зависимости от быстродействия внутри ROM на выходе будут неустойчивые состояния.
    Цитата Сообщение от Sergei Frolov Посмотреть сообщение
    А как можно заменить ПЛМ на ПЗУ?
    Если есть файл прошивки РТ2, если есть табличка истинности типа такой как на примере или записанная РТ2, с которой можно считать содержимое программатором или собрав простой преобразователь на 16-разрядном счетчике и буфере. При переборе адреса 15..0 на входе, на выходе получим данные 7..0 по соответствующему адресу для записи в ROM. ВВ55 в помощь
    Этот пользователь поблагодарил MVV за это полезное сообщение:
    cy6(29.04.2023)
  1. Контроллер дисковода
    Ответов: 55
    Последнее: 12.04.2024, 16:33
  2. Ответов: 26
    Последнее: 25.01.2019, 18:31
  3. Ответов: 24
    Последнее: 30.04.2016, 23:47
  4. Не работает контроллер дисковода GRM2+
    от Shnurkov в разделе Внешние накопители
    Последнее: 16.03.2009, 00:59
  5. Куплю контроллер дисковода для УКНЦ
    от tnt23 в разделе Барахолка (архив)
    Последнее: 27.02.2009, 08:51
