Добавил в [1,2]startup.cmd запуск decnet:
и теперь при выполнении shutup.cmd не отмонтируется системный диск DB0:Код:.SETT $CEX .SETT $DEC .SETT $NNS ASN LB:=XX: .SETF $LAT @LB:[5,1]NETINS
Это так и должно быть или перед shutup нужно отключать decnet?Код:>RUN $SHUTUP RSX-11M-PLUS Shut down program Enter minutes to wait before shutdown: Reason for shutdown (<CR> for none): OK to shutdown? [Y/N]: Y All further logins are disabled 22-JAN-16 10:59 System is now shutting down -- PISTON QUE /STO:QMG > STOP/ACCOUNTING SHUTUP 10:59:52 SYSLOG -- 47. Exiting > @LB:[1,2]SHUTUP >VCP DISCONNECT /ALL >@ <EOF> > ELI /NOLOG > ACS DB0:/BLKS=0. ACS -- Checkpoint file now inactive > DMO DB0:/DEV/LOCK=V DMO -- System disk being dismounted DMO -- SYSTEM dismounted from DB0: *** Final dismount initiated *** > Command (DMO) Timeout - Continue waiting? [Y/N]: N DMO NS0:/DEV/LOCK=V DMO -- SYSTEM dismounted from NS0: *** Final dismount initiated *** > Event type 68.14, Normal usage terminated Occurred 22-JAN-16 11:00:13 on node 1.77 (PISTON) Circuit UNA-0 Event type 2.0, Local node state change Occurred 22-JAN-16 11:00:15 on node 1.77 (PISTON) Reason for state change: Operator command, Old node state = On New node state = Off SHUTUP operation complete
Ответить с цитированием
