Показано с 11 по 19 из 19
Тема: Pentagon 128k debugging
    Berlin, Germany
    47
    31 сообщений
    The computer crashing after a few seconds has been fixed indeed (was caused by a faulty connection of C7). But there's still 1 problem remaining.
    KJoy does not seem to work at all - #1f reads all 255. I could get that semi-fixed by adjusting R11 to 1MOhm, which allows me to randomly use the joystick (#1f reads 0 or 255), but this also makes the machine a good bit more unstable, since it sometimes would give me a black screen with white border and random disk access when powering up.
    Using /IORQ instead of /OIRQ to drive the joystick interface allows me to use the joystick without any issue (#1f all 0 and reacting to input) but eliminates TRDOS (listing a disk gives me a *no disk* error)
    Any ideas what could be wrong there?
    Pentagon 48 + MIKAY128 + VG93 Turbo + Stereo Covox + KJoy
    Москва 128 + AY
    Pentagon 1024SL 2.2 + ZXM-GS + Z-Controller + TSFM + Tape-In
    ZX Evolution Rev. C + ZX-MultiSound
    Compact 256 Turbo 1.1 (ZS Scorpion 256 INT, Port #FF, Port #FB) + Covox + ProfROM + NemoBus + NemoIDE + ZXM-GS
    ZS Scorpion 256 Turbo+ + GMX + SMUC + GS Classic 2MB
    Sprinter 2016S
    К сожалению, я не говорю по-русски / Sorry, I don't speak Russian
    https://github.com/zxshock
    379
    242 сообщений
    try to replace silicon diodes on germanium diodes or Schottky diodes with small voltage drop on P-N transition. The R11 resistor shall be 10 kOhms. On scheme (http://sblive.narod.ru/ZX-Spectrum/P...28VMGPage3.jpg) used /OIRQ signal and germanium diodes Д9.
    Profi must live!
    Моё железо...
    Все укомплектованы:
    Berlin, Germany
    47
    31 сообщений
    I'll try that with adjusting R11 to 10kOhms, in case that alone won't help, I'm going to drive /RD, /OIRQ and A5 through OR-gates as shown here: http://8bit.yarek.pl/hardware/zx.joystick/kjschem.gif
    Москва 128 + AY
    Sprinter 2016S
    Berlin, Germany
    47
    31 сообщений
    Good news, disabling the diodes and instead using OR-Gates (74ls32/555ЛЛ1) the kempston interface works reliable. #1f outputs all 0 and reacts to joystick inputs, while floppy access works nicely
    Москва 128 + AY
    Sprinter 2016S
    Berlin, Germany
    47
    31 сообщений
    After almost a year it's me again.
    I tried to power up my Pentagon once again, sadly the video output seems to be extremely butchered. Otherwise the computer seems to work (keyboard, menu, sound, trdos).
    Here's a picture of the output (3MB): http://imageshack.com/a/img11/2371/ojpv.jpg
    The problem is as follows: all characters shown on screen are just very delicate shadows of what they're supposed to be, there's no color - except when entering the tape loader which causes the whole screen to flash in red and cyan.
    The scart cable is correct (connecting R, G and B - SYNC on Pin20, +5V on Pin16)
    Any idea where to start? I've already tried counterswapping most of the Pentagon logic chips and replaced the VT1 & VT2 transistors.
    Москва 128 + AY
    Sprinter 2016S
    Berlin, Germany
    47
    31 сообщений
    Seems like this was related to the PSU. Using another one I got a proper picture and managed to load half a demo before the machine crashed.
    Time to add some more decoupling caps and a properly adjusted PSU
    Москва 128 + AY
    Sprinter 2016S
    г. Днепропетровск
    20
    11 сообщений
    The essence of the question is not very clear. To facilitate the understanding of fault recommend to make a video of what is happening on the screen to make it clearer to others, in what appears a fault.
    ---------- Post added at 07:58 ---------- Previous post was at 07:57 ----------
    Shockwav3 Recommend to continue the discussion here http://zx.pk.ru/showthread.php?t=14277&page=43
    ---------- Post added at 07:59 ---------- Previous post was at 07:58 ----------
    topic is more relevant here.
    Berlin, Germany
    47
    31 сообщений
    And another patient, this time a Pentagon 1024SL 2.2
    For some reason I can't get the RGB Video working, as I just get a white screen (second photo on the first image). Composite Video seems to work (upper picture). Connecting SYNC via Composite, I get a slight tint of the image as I should. Since I get a fully white picture when using the SCART cable I suppose the mode switching (pin 16) works as it should.
    The second image is the pinout I used to connect a SCART connector.
    I already doublechecked R42 ... R53 and VT13 ... VT15.
    Any ideas what could be wrong?
    И еще один пациент, на этот раз Пентагон 1024SL 2.2
    По некоторым причинам я не могу RGB Видео работает, как я только получить белый экран (второе фото на первом изображении). Композитный видео, кажется, работает (верхний рисунок). Подключение SYNC через Composite, я получаю небольшой оттенок изображения, как я должен. Так как я получить полностью белое изображение при использовании SCART кабель Я предполагаю, что переключение режимов (контактный 16) работает как надо.
    Второе изображение является распиновка я использовал для подключения разъем SCART.
    Я уже перепроверили R42 ... R53 и VT13 ... VT15.
    Любые идеи, что может быть не так?
    https://imagizer.imageshack_.us/v2/3...90/31/csbe.jpg
    https://imagizer.imageshack_.us/v2/4...0/534/n10k.jpg
    Последний раз редактировалось Shockwav3; 16.02.2014 в 17:35.
    Москва 128 + AY
    Sprinter 2016S
    Украина, г. Сумы
    For switch TV to RGB mode, you need connect pin 16 of SCART to 5 V through 180 Ohm resistor.
  1. Как быть с реалом - Pentagon 128k ?
    от dM_GBG в разделе Pentagon
    Ответов: 49
    Последнее: 14.01.2021, 18:05
  2. куплю pentagon 128k
    от ZX1997 в разделе Барахолка (архив)
    Последнее: 12.01.2012, 14:41
  3. Помогите с Pentagon-128k !
    от r0m в разделе Pentagon
    Ответов: 383
    Последнее: 15.05.2010, 02:51
  4. Ответов: 57
    Последнее: 03.04.2010, 07:42
  5. Ответов: 0
    Последнее: 24.01.2010, 21:46
