Страница 6 из 13 ПерваяПервая ... 2345678910 ... ПоследняяПоследняя
Показано с 51 по 60 из 126
Тема: ZEsarUX Emulator
  1. #51
    г. Арзамас
    173
    121 сообщений
    Цитата Сообщение от chernandezba Посмотреть сообщение
    not perfect
    key point xD
    http://prods.tslabs.info/files/Chess.zip
  2. #52
    Воронеж
    314
    237 сообщений
    n.c.
    afaik it depends on specific pentagon variant
    different demos were made for slightly different timings
  3. #53
    Madrid, Spain
    46
    18 сообщений
    n.c.
    See
    https://twitter.com/zesarux/status/1...843001856?s=21
    Последний раз редактировалось chernandezba; 12.09.2019 в 23:33.
  4. #54
    Madrid, Spain
    46
    18 сообщений
    По умолчанию ZEsarUX Beta 8.1
    Hi!
    I have uploaded a new ZEsarUX 8.1 BETA version. You can download compiled versions for Windows, Mac, and the source code from:
    https://github.com/chernandezba/zesa...g/8.1-07112019
    Changelog is:
    Added ZEsarUX Network Gaming protocol (ZENG), which allows you to play to any emulated game, using two ZEsarUX instances,
    located each one on any part of the world or in a local network. Games doesn't have to be modified, you can use any existing game
    Added Pentagon 16C colour mode emulation
    Added 1024 KB RAM emulation for Spectrum & Pentagon
    Added support for .scl files: can be converted from file selector menu pressing space
    Added SNA saving support
    Added PZX tape file support
    Added ZX81 online game browser
    Added Spectrum online game browser
    Added total run time statistics
    Added checking for updates
    Added sending anonymous statistics use
    Added setting --disablemenuandexit: it closes the emulator when the menu is going to be opened.
    It's the same behaviour as previous --disablemenu. Now --disablemenu only disables the menu but does not close the emulator
    Added Borland Gui Style
    Added ZRCP commands:
    -cpu-code-coverage: working with code coverage
    -cpu-history: working with cpu history
    -get-ui-io-ports: to get keyboard state and joystick
    -get-snapshot: get a ZSF snapshot from ZRCP
    -print-footer: print message on footer
    -put-snapshot: put a ZSF snapshot from ZRCP
    -send-keys-event: simulates key press/release
    -set-ui-io-ports: to change keyboard state and joystick
    -write-port: write value to a port
    Added internal zip decompressor: no more need to use external unzip program
    Added setting to reset configuration file to default values
    Improved Debugging:
    -added setting to dump .zsf snapshot when a cpu panic is fired
    -debug CPU window: can now resize height and have more debug lines
    -cpu transaction log: faster when opening transaction log file
    -added key 'n' for "run" on debug cpu. Does the same as closing all menus and returning back to emulation
    Improved TBBlue emulation:
    -added scroll x,y on ula layer
    -optimized ula,lores render routines: 2% less cpu on my computer
    -added 1-bit tile mode
    Improved Hex editor: can now copy to a different memory zone
    Improved menu:
    -can now use PgUp,PgDn to jump menu pages
    -added setting to disable File Utilities menu
    Improved assembler: added defs command
    Improved AY Sheet: now you can select which AY Chip to show
    Improved file selector: when asking for a directory, only shows directories, not files
    Improved curses driver: symbol @ simulates ESC on menu
    Improved snapshot loading: now setting "--sna-no-change-machine" becomes "--snap-no-change-machine" and applies to .sna and .z80
    Improved curses driver: now can use utf "blocky" characters and have 64x48 resolution
    Improved accurate Z80 timing: IM mode 0 is 1 t-state shorter than IM mode 1
    Improved real tape loading: acceleration is disabled by default, added setting to save configuration
    Fixed Pentagon border: now ukflag demo is perfect
    Fixed Spectrum 128k machines border: now ula128, scroll2017 demos are perfect
    Fixed f_seek call on esxdos handler
    Fixed segfault error when using breakpoints like peek/opcode in config file
    Fixed bug on zxuno changing video ram 5/7 when paging was disabled by bit DI7FFD
    Fixed average cpu statistics when footer is not enabled
    Fixed kempston mouse emulation on Next machine: wheel bits always return 0
    Fixed bug extracting PAWS words when a word is a pronoun
    Fixed undocumented opcode ED76: I had IM0 but it's IM1
    Fixed loading and saving +3 .z80 snapshots
    Fixed placing menu windows when using zx desktop and machines TSConf, TBBlue, CPC and QL
    Fixed bug loading .sna files when rom 1 paged in
    Fixed very-old bug when loading Rocman game. This bug existed even on ZXSpectr. It fixes return flags when using tape traps.
    Rocman loading screen was shown wrong (having the "any flag loading setting" disabled), but loaded. Enabling that setting crashed the game
    Эти 2 пользователя(ей) поблагодарили chernandezba за это полезное сообщение:
    Lethargeek(09.11.2019), Rusazar(08.11.2019)
  5. #55
    119
    80 сообщений
    Could you please share screenshots?
  6. #56
    275
    167 сообщений
    г. Таллин, Эстония
    223
    159 сообщений
    What about win binary?
    Arrgh, newer mind, found it at the end of page.
    Seems, I'm little sleepy now.
    But anyway...
    Последний раз редактировалось Bedazzle; 09.11.2019 в 14:24.
    Heavy on the disasm
    Eric and the disasm
    Mask 3: Venom strikes disasm
    Bard's disasm
  8. #58
    Madrid, Spain
    46
    18 сообщений
    But anyway...
    Thanks. Seems some windows need this dll. I will include it in the next release
  9. #59
    г. Таллин, Эстония
    223
    159 сообщений
    Mine is Win7 Home Premium.
    Heavy on the disasm
    Eric and the disasm
    Bard's disasm
  10. #60
    Madrid, Spain
    46
    18 сообщений
    По умолчанию ZEsarUX 8.1 stable
    Hi!
    I've uploaded a new ZEsarUX 8.1 stable version.
    Go to the github released webpage to download it:
    https://github.com/chernandezba/zesa...leases/tag/8.1
    I recommend you to watch the video…
    Changelog is:
    Version 8.1 - The Great Escape edition. 25 February 2020
    Added Spectrum and ZX81 online game browser. You can search & play almost any game for these machines!
    Added real joystick support on Windows
    Added ZIP files support: no more need to use external unzip program
    Added SCL files support: can be converted from file selector menu pressing space
    Added SCR to TAP file converter
    Added setting to disable looking for alternate character sets from sysvar 23606/7 on ocr functions
    Added DataDrive HiLow emulation (beta)
    Added setting to choose cpu type
    -extended-stack: having an internal stack for debugging stack value types
    -New Wizard to automatically download and configure TBBlue official SD images
    -added tbblue register 63H: copper 16 bit write
    -added tbblue register 69H: display control 1 register
    -added tbblue registers 0x35-0x39, 0x75-0x79
    -added copper opcodes NOOP, HALT
    -increased tbblue.mmc MMC bundled image size to 64 MB
    -updated to the latest tbblue SD distribution.
    -enable real video by default
    -added zsf snapshot support
    -supports setting Core ID to ZX Dos
    -supports changing Core version
    Improved Debugging:
    -debug CPU window: can now resize height and have more debug lines, legend keys expand as width increases, registers located at the most right position
    -debug CPU window: show interrupt routine pointer on im2 mode
    -can now copy to a different memory zone
    -shows the memory pointer when editing memory
    Improved menu:
    -added more cyrillic characters support
    -Splitted source code repository: now extras folder has been moved to another repository. See:
    https://github.com/chernandezba/zesarux-extras
    Improved Waveform: new scroll type
    Improved cpu speed change: now it's a lot faster
    Improved accesibility:
    -disabled menu items (the ones in red) are now called as "unavailable" instead of "disabled"
    -selected item menu is called now "Selected item" (was called "Active item" before)
    -say when a selected menu item is not available
    -pressing F4 key on a window menu, it will read that window again
    -Mac OS speech filter doesn't fail anymore when message has "-"
    -when an error is generated on stdout driver, the message is sent to text-to-speech
    Fixed segfault error when trying to open a directory with no permissions
    Fixed error when trying to open user files on MacOS Catalina
    Fixed RETI behaviour
    Fixed Real Joystick support: buttons to event table is not set to defaults automatically anymore
    Fixed bug on return flags from tape load trap. It only affected Rocman game and enabling "any flag loading" setting
    Fixed setting a configured memory breakpoint like this "--set-mem-breakpoint 0000H 2" which was fired on startup
    Fixed showing memory banks on debug cpu for Z88 machine
    Fixed menu issues:
    -fixed generic message splash: wait until key is released (if any pressed)
    -fixed opening the menu on stdout driver on the first start of ZEsarUX
    -fixed bug closing menu on Z88 machine and Real Video disabled
    Fixed tbblue emulation:
    -fixed clipping in 80x32 mode
    -fixed error when paging rom in ram, on case pages 0,1,2,3
    -fixed "bit 7 = Disable ULA output (soft reset = 0)" on register 0x68
    -fixed turbosound and dac activation when tbblue fast boot mode
    -added turbo mode x8 (28 MHz)
    -fixed reading register 7
    -fixed RTC emulation
    -fixed autoload tape
    Fixed Accessibility bugs:
    -now menu settings (anything between square brackets []) are played at the end of the menu line
    -now menu settings ([ ] and [X]) are played as "enabled"/"disabled"
    Some other minor bugfixes and improvements
    I hope you enjoy it!
    Cheers
    César
    Эти 7 пользователя(ей) поблагодарили chernandezba за это полезное сообщение:
    andykarpov(27.02.2020), Black Cat / Era CG(27.02.2020), BobrovS(27.02.2020), doorsfan(27.02.2020), Doronetty(27.02.2020), Lethargeek(27.02.2020), SoftLight(13.06.2020)
  1. Speccy emulator
    от Rindex в разделе Эмуляторы
    Ответов: 53
    Последнее: 13.07.2022, 22:50
  2. CHIP8 Emulator
    от NEO SPECTRUMAN в разделе Софт
    Ответов: 37
    Последнее: 05.11.2020, 22:24
  3. Agat Emulator v1.26.1
    от Rindex в разделе Apple
    Последнее: 15.02.2014, 22:02
