Страница 24 из 25 ПерваяПервая ... 202122232425 ПоследняяПоследняя
Показано с 231 по 240 из 243
Тема: GMX - (Grafic Memory eXpander) сводная тема.
  1. #231
    Berlin, Germany
    46
    31 сообщений
    Finally got around to installing the GMX.
    Works without touching DD47/49 or DD30.
    Tested so far: Pentagon INT, floppy access, SMUC, ZXM-GS, Edge Grinder GMX & Ansi Viewer
    EDIT: Across the Edge (fix0) crashed at the "Outbordering" Screen around the 3 minute mark.
    EDIT2: implemented D47 fix, works fine now.
    Последний раз редактировалось Shockwav3; 03.01.2023 в 08:16.
    Pentagon 48 + MIKAY128 + VG93 Turbo + Stereo Covox + KJoy
    Москва 128 + AY
    Pentagon 1024SL 2.2 + ZXM-GS + Z-Controller + TSFM + Tape-In
    ZX Evolution Rev. C + ZX-MultiSound
    Compact 256 Turbo 1.1 (ZS Scorpion 256 INT, Port #FF, Port #FB) + Covox + ProfROM + NemoBus + NemoIDE + ZXM-GS
    ZS Scorpion 256 Turbo+ + GMX + SMUC + GS Classic 2MB
    Sprinter 2016S
    К сожалению, я не говорю по-русски / Sorry, I don't speak Russian
    https://github.com/zxshock
    Этот пользователь поблагодарил Shockwav3 за это полезное сообщение:
    Evgeny Muchkin(03.01.2023)
  2. #232
    Berlin, Germany
    46
    31 сообщений
    Test 4.3 (when measuring INT/testing AY) and hft 1.02 (when checking port FD) both seem to crash since I upgraded to GMX ROM 5.01 ... they were working previously.
    Also another small fluke, Covox/LPT port seems to be mapped to DD/221 in Pentagon config, also seems to clash with the screen as one gets artefacts.
    Computer previously was randomly switching between Turbo modes (Scorpion config) when accessing disks, this has stopped since I removed the Turbo + ProfROM GALs and the ProfROM itself.
    Apart from that - thank you very much Evgeny Muchkin - it's a very interesting piece of hardware!
    Москва 128 + AY
    Sprinter 2016S
  3. #233
    Berlin, Germany
    46
    31 сообщений
    Crashes in hft 1.02 and Test 4.3 seem to be related to the Shadow Monitor/Magic Button?
    If I press the button shortly before the tests and exit ShadowMon they seem to run fine.
    Where is GMX X1-2 supposed to go? Pin 22B on the expansion port of my Scorpion 256 Turbo+ is VCC. I've left it unconnected so far.
    Москва 128 + AY
    Sprinter 2016S
  4. #234
    362
    198 сообщений
    X1-2 can not be connected.
    Этот пользователь поблагодарил Evgeny Muchkin за это полезное сообщение:
    Shockwav3(07.01.2023)
  5. #235
    Berlin, Germany
    46
    31 сообщений
    Thank you
    Would I need to implement this modification on my Turbo+?
    Москва 128 + AY
    Sprinter 2016S
  6. #236
    362
    198 сообщений
    No!
    Can get issues with Across the Edge, Eyeache2... in pentagon mode.
  7. #237
    Berlin, Germany
    46
    31 сообщений
    Has anyone figured out yet why Test 4.3 and HFT 1.02 hang/crash and if there's a potential fix in hardware? HFT apparently only crashes sometimes, with garbage on the screen, while still being able to enter the ShadowMon sometimes.
    Doesn't seem to be related to the GMXROM as I tried downgrading without effect.
    Москва 128 + AY
    Sprinter 2016S
  8. #238
    г. Тотьма
    343
    182 сообщений
    Хочется ещё раз прояснить для себя состояние дел по поводу отсутствия исходников прошивки ПЛИС. Поправьте меня:
    1. Никто не мешает написать новую прошивку, которая будет работать точно или почти точно как старая?
    2. Затем добавлять в неё что хочется. Например, режим АТМ и Профи.
    3. Затем разработать новую версию железки с более жирной ПЛИС. Сделать 28 МГц, 4 ядра и прочее.
    Правильно?
    Leningrad 1/Sega Joy Adapter
    DivGMX
    ZX Spectrum +2A
    ZX Evolution rev. C
    362
    198 сообщений
    Цитата Сообщение от izzx Посмотреть сообщение
    Правильно?
    Правильно!
  10. #240
    Berlin, Germany
    46
    31 сообщений
    Any chance if there will ever be fixed hardware schemes?
    Using GMX on my Turbo+ I get 69888 tacts per INT *without* waitstates, instead of 70784 without wait (Turbo+, green PCB) or 69888 *with* waitstates (256, yellow PCB), breaking various effects in demos using multicolor timings.
    Есть ли шанс, что когда-нибудь будут исправлены аппаратные схемы?
    Используя GMX на Turbo+, я получаю 69888 тактов на INT *без* ожидания, вместо 70784 без ожидания (Turbo+, зеленая PCB) или 69888 *с* ожиданием (256, желтая PCB).
    Москва 128 + AY
    Sprinter 2016S
  1. ZXGC (ZX Grafic Card made by Doktor)!
    от ZXFanat в разделе Изображение
    Ответов: 89
    Последнее: 30.08.2023, 20:41
  2. Atari 130XE/65XE memory upgrade 1MB (4bit memory chips)
    от dkamenski в разделе Atari
    Ответов: 15
    Последнее: 12.01.2016, 16:20
  3. demoscene memory
    от TmK в разделе Люди
    Ответов: 52
    Последнее: 04.05.2013, 23:01
  4. GMX
    от drbars в разделе Изображение
    Последнее: 29.07.2007, 01:49
  5. GMX
    от spensor в разделе Scorpion
    Ответов: 43
    Последнее: 25.03.2007, 11:49
