Страница 26 из 29 ПерваяПервая ... 2223242526272829 ПоследняяПоследняя
Показано с 251 по 260 из 282
Тема: Универсальный контроллер PS/2 клавиатуры для компьютеров с матричными клавиатурами.
  1. #251
    г. Смоленск
    Уважаемый Xrust, хотел попросить вас доработать программу и вывести на свободные ноги Атмеги два сигнала , сброс при нажатии ctrl, alt , del ,и nmi при нажатии какой нибудь функциональной клавиши.
  2. #252
    г. Тольятти
    169
    82 сообщений
    Набросал сегодня на скорую руку прошивку для УКНЦ.
    //UKNZ
    #include <PS2KeyRaw.h>
    #define AX0 4
    #define AX1 5
    #define AX2 6
    #define AX3 7
    #define AY0 8
    #define AY1 9
    #define AY2 10
    #define RSTMT 14
    #define CSMT  15
    #define DATMT 16
    #define STBMT 17
    #define DATAPIN 2
    #define IRQPIN  3
    #define LAT 0
    #define EXT 1
    #define RUS 2
    volatile boolean d = HIGH;
    volatile uint8_t lang = LAT;
    volatile uint8_t e = lang;
    uint8_t table[3][132] = {{127,116,127,8,5,3,4,127,127,11,100,117,7,17,0,127,
    127,65,64,127,33,50,19,127,127,127,106,68,53,52,20,127,
    127,35,72,42,22,6,21,127,127,70,90,34,71,55,23,127,
    127,39,57,105,40,51,24,127,127,127,69,18,36,9,10,127,
    127,74,37,54,56,121,122,127,127,88,118,41,2,38,67,127,
    127,127,58,127,25,120,127,127,66,49,102,26,127,89,127,127,
    127,127,127,127,127,127,85,127,127,82,127,83,80,127,127,127,
    81,97,98,99,115,96,1,127,127,84,114,16,84,112,127,127,
    127,127,127,101},
    {127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,
    127,49,127,127,33,127,127,127,127,127,127,127,127,127,127,127,
    127,127,127,127,127,127,127,127,127,127,119,127,127,127,127,127,
    127,127,127,127,127,127,127,127,127,127,113,127,127,127,127,127,
    127,127,127,127,127,127,127,127,127,127,127,73,127,127,127,127,
    127,127,87,127,86,103,127,127,127,127,127,127,127,127,127,127,
    127,127,127,127},
    {127,116,127,8,5,3,4,127,127,127,100,117,7,17,127,127,
    127,65,64,127,33,18,19,127,127,127,50,51,34,35,20,127,
    127,68,67,52,36,6,21,127,127,70,69,53,22,37,23,127,
    127,71,54,55,38,39,24,127,127,127,72,56,40,9,10,127,
    127,57,41,25,26,121,122,127,127,58,119,42,90,106,67,127,
    127,127,89,127,105,120,127,127,66,49,102,104,127,127,127,127,
    81,97,98,99,115,96,1,127,127,127,114,16,84,112,127,127,
    127,127,127,101}};
    PS2KeyRaw keyboard;
    void setup() {
      //Инициализация портов
      pinMode(AX0, OUTPUT);   //AX0
      pinMode(AX1, OUTPUT);   //AX1
      pinMode(AX2, OUTPUT);   //AX2
      pinMode(AX3, OUTPUT);   //AX3
      pinMode(AY0, OUTPUT);   //AY0
      pinMode(AY1, OUTPUT);   //AY1
      pinMode(AY2, OUTPUT);   //AY2
      pinMode(RSTMT, OUTPUT); //RES
      pinMode(CSMT, OUTPUT);  //CS
      pinMode(DATMT, OUTPUT); //DAT
      pinMode(STBMT, OUTPUT); //STB
      //Инициализация клавиатуры
      keyboard.begin( DATAPIN, IRQPIN );
      //Инициализация MT8816
      SetAddr(0);
      digitalWrite(RSTMT, LOW);
      digitalWrite(CSMT, LOW);
      digitalWrite(DATMT, LOW);
      digitalWrite(STBMT, LOW);
      InitMt();
    //Сброс MT
    void InitMt() {
      digitalWrite(STBMT, HIGH); //инициализация
      digitalWrite(CSMT, HIGH); //выбор чипа
      digitalWrite(RSTMT, HIGH);
      digitalWrite(RSTMT, LOW);  //сброс
    //Установка адреса MT
    void SetAddr(uint8_t addr) {
      digitalWrite(AX0,bitRead(addr,0));
      digitalWrite(AX1,bitRead(addr,1));
      digitalWrite(AX2,bitRead(addr,2));
      digitalWrite(AX3,bitRead(addr,3));
      digitalWrite(AY0,bitRead(addr,4));
      digitalWrite(AY1,bitRead(addr,5));
      digitalWrite(AY2,bitRead(addr,6));
    //Установка ключа MT
    void SetKey(boolean data){
       digitalWrite(STBMT, HIGH); //строб on
       digitalWrite(DATMT, data); //данные
       digitalWrite(STBMT, LOW); //строб off
    void loop()
      if( keyboard.available() ){
        int c = keyboard.read(); //чтение кода
        switch (c) {
          case 0xE1:              //Если считался префикс 0xE1 сброс MK
            InitMt();
            break;
          case 0xE0:              //Если считался префикс 0xE0
            e = EXT;              //тогда код будет из table[1]
            break;
          case 0xF0:              //Если считался префикс 0xF0 (отпускание клавиши)
            d = LOW;              //тогда готовимся записывать "0" в MT
            break;
          case 0x78:              //Если считался код 0x78 [F11]
            lang = RUS;           //переключаемся на русскую раскладку
            e = lang;
            d = HIGH;             //помним о 0xF0 при отпускании [F11],
            break;                //фактически раскладка переключается дважды.
          case 0x07:              //Если считался код 0x07 [F12]
            lang = LAT;           //переключаемся на латинскую раскладку
            e = lang;
            d = HIGH;             //помним о 0xF0 при отпускании [F12]
            break;
          default:
            SetAddr(table[e][c]); //получаем адрес ключа из текущей таблицы
            SetKey(d);            //переключаем ключ в состояние d
            d = HIGH;             //если было отжатие ключа, принудительно переводим в нажатие
            e = lang;             //если был код из table[1], возвращаем на текущую раскладку
    Переключение раскладок: F11-русская F12-латинская.
    Кое-что еще требует доработки, кое-какие клавиши, наверное, стоит переназначить. Клавиши ПОМ УСТ ИСП СБРОС соответствуют F6 F7 F8 F9, чтобы было удобнее в Турбо Бейсике. Клавиша СТОП пока не реализована, ее надо отдельно делать.
    Последний раз редактировалось Xrust; 02.03.2024 в 11:04.
  3. #253
    Bryansk
    140
    107 сообщений
    Сильно на скорую. Не реализована клавиша ФИКС, на сколько я понимаю. Значит CAPS придется реализовывать зажатым Shift'ом. Да и РУС/ЛАТ не пойми как будут работать - они тоже ФИКС'ом фиксируются.
  4. #254
    г. Тольятти
    169
    82 сообщений
    Неправильно понимаете. Реализованы все клавиши, кроме СТОП.
  5. #255
    Bryansk
    140
    107 сообщений
    Надо, короче, пробовать и смотреть как работает...
  6. #256
    г. Тольятти
    169
    82 сообщений
    Доработал немного прошивку под УКНЦ. Добавил сброс MT клавишей [Break] и пофиксил ошибки.
    P.S. Победил и [STOP]. Полностью все клавиши работают. Если только какие-то мелкие замечания устранить.
    Схема подключения:
    J2(8..1) контроллера >> XS3(8..1) УКНЦ, J3(12..1) контроллера >> XS4(12..1) УКНЦ, J3(13) контроллера >> XS3(9) УКНЦ.
    Ну и, естественно, контроллер с этой прошивкой можно подключить и к Ориону-128, к которому так же подключали клавиатуру МС7007.
    Последний раз редактировалось Xrust; 02.03.2024 в 00:55.
  7. #256
  8. #257
    г. Тольятти
    169
    82 сообщений
    Новая версия прошивки для Спектрум 128
    Добавлен сброс матрицы клавишей [Pause Break].
    #define AX0 4
    #define AX1 5
    #define AX2 6
    #define AX3 7
    #define AY0 8
    #define AY1 9
    #define AY2 10
    #define RSTMT 14
    #define CSMT  15
    #define DATMT 16
    #define STBMT 17
    #define DATAPIN 2
    #define IRQPIN  3
    uint8_t table[128] = {127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,0,127,127,32,48,127,127,127,1,17,16,33,49,127,
    127,3,2,18,34,51,50,127,127,112,4,19,36,35,52,127,127,115,116,100,20,84,68,127,127,127,114,99,83,67,66,127,
    127,127,98,82,81,64,65,127,127,127,127,97,127,80,127,127,127,127,127,127,127,127,127,127,127,113,96,127,127,127,127,127,
    127,127,127,127,127,127,64,127,127,127,127,52,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127};
    PS2KeyRaw keyboard;
    void setup() {
      SetAddr(0);
      InitMt();
    //Сброс MT
    void InitMt() {
    void loop()
        switch (c) {
            InitMt();
            break;
          case 0xE0:              //если считался префикс 0xE0
            break;
          case 0xF0:              //если считался префикс 0xF0 (отпускание клавиши)
            d = LOW;
            break;
          case 0x66:              //если считался код 0x66 [BS]
            SetAddr(table[0x12]);
            SetKey(d);
            SetAddr(table[0x45]);
            SetKey(d);
            d = HIGH;
            break;
          case 0x6B:              //если считался код 0x6B [Left]
            SetKey(d);
            SetAddr(table[0x2E]);
            SetKey(d);
            d = HIGH;
            break;
          case 0x72:              //если считался код 0x72 [Down]
            SetKey(d);
            SetAddr(table[0x36]);
            SetKey(d);
            d = HIGH;
            break;
          case 0x75:              //если считался код 0x75 [Up]
            SetKey(d);
            SetAddr(table[0x3D]);
            SetKey(d);
            d = HIGH;
            break;
          case 0x74:              //если считался код 0x74 [Right]
            SetKey(d);
            SetAddr(table[0x3E]);
            SetKey(d);
            d = HIGH;
            break;
          case 0x76:              //если считался код 0x76 [Edit]
            SetKey(d);
            SetAddr(table[0x16]);
            SetKey(d);
            d = HIGH;
            break;
          case 0x58:              //если считался код 0x58 [Caps lock]
            SetKey(d);
            SetAddr(table[0x1E]);
            SetKey(d);
            d = HIGH;
            break;
          case 0x0D:              //если считался код 0x0D [Ext mode]
            SetKey(d);
            SetAddr(table[0x59]);
            SetKey(d);
            d = HIGH;
            break;
          case 0x41:              //если считался код 0x41 [,]
            SetKey(d);
            SetAddr(table[0x31]);
            SetKey(d);
            d = HIGH;
            break;
          case 0x49:              //если считался код 0x49 [.]
            SetKey(d);
            SetAddr(table[0x3A]);
            SetKey(d);
            d = HIGH;
            break;
          case 0x4C:              //если считался код 0x4C [;]
            SetKey(d);
            SetAddr(table[0x44]);
            SetKey(d);
            d = HIGH;
            break;
          case 0x52:              //если считался код 0x52 ["]
            SetKey(d);
            SetAddr(table[0x4D]);
            SetKey(d);
            d = HIGH;
            break;
          default:
            SetAddr(table[c]);
            SetKey(d);
            d = HIGH;
    г. Смоленск
    Что значит сброс матрицы? Какое действие он производит?
  10. #259
    г. Тольятти
    169
    82 сообщений
    Производит инициализацию матрицы. Если вдруг какие-то ключи "залипли", чтобы долго не искать.
  11. #260
    г. Волгоград
    472
    254 сообщений
    Сделал прошивку под Вектор-06ц (она же подходит и для ПК-6128ц -- там клавиатуры одинаковые). Для показа состояния индикатора "РУС" использовал на клавиатуре индикатор ScrollLock, для индикатора "СЕТЬ" -- NumLock. Для того, чтобы задействовать эти индикаторы пришлось перейти с библиотеки PS2KeyRaw на PS2KeyboardHost (есть в библиотеке ArduinoIDE).
    Скетч
    // Вектор-06ц / ПК-6128ц
    #include "ps2_Keyboard.h"
    #include "ps2_NullDiagnostics.h"
    #define AX0 4
    #define AX1 5
    #define AX2 6
    #define AX3 7
    #define AY0 8
    #define AY1 9
    #define AY2 10
    #define SS 11     // J1:4
    #define US  12    // J1:1
    #define RUS 13    // J1:3
    #define VVD 1     // H2:TX
    #define SBR 0     // H2:RX
    #define IRUS 18   // вывод 27
    #define RSTMT 14
    #define CSMT  15
    #define DATMT 16
    #define STBMT 17
    #define DATAPIN 2
    #define IRQPIN  3
    // J2 -- PB
    // J3 -- PA
    typedef ps2::NullDiagnostics Diagnostics_;
    static Diagnostics_ diagnostics;
    static ps2::Keyboard<DATAPIN, IRQPIN, 1, Diagnostics_> ps2Keyboard(diagnostics);
    static ps2::KeyboardLeds lastLedSent = ps2::KeyboardLeds::none;
    volatile boolean OldRUS;
    volatile boolean extkey = LOW;
    const uint8_t table[128] = {0xFF, 0xFF, 0xFF, 0x71, 0x51, 0x31, 0x41, 0xFF,  //   0 00 -  -  -  F5 F3 F1 F2 - (код клавиши PB PA)
                                0xFF, 0xFF, 0xFF, 0xFF, 0x61, 0x00, 0x33, 0xFF,  //   8 08 -  -  -  -  F4 TB ;  -
                                0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x25, 0x12, 0xFF,  //  16 10 -  -  -  -  -  J  1  -
                                0xFF, 0xFF, 0x16, 0x17, 0x64, 0x34, 0x22, 0xFF,  //  24 18 -  -  Q  Y  F  C  2  -
                                0xFF, 0x36, 0x67, 0x76, 0x56, 0x42, 0x32, 0xFF,  //  32 20 -  S  ^  W  U  4  3  -
                                0xFF, 0x77, 0x55, 0x14, 0x54, 0x35, 0x52, 0xFF,  //  40 28 -  _  M  A  E  K  5  -
                                0xFF, 0x46, 0x15, 0x26, 0x06, 0x65, 0x62, 0xFF,  //  48 30 -  T  I  R  P  N  6  -
                                0xFF, 0xFF, 0x07, 0x75, 0x74, 0x72, 0x03, 0xFF,  //  56 38 -  -  X  O  G  7  8  -
                                0xFF, 0x24, 0x45, 0x37, 0x57, 0x02, 0x13, 0xFF,  //  64 40 -  B  L  [  ]  0  9  -
                                0xFF, 0x04, 0x43, 0x44, 0x66, 0x27, 0x53, 0xFF,  //  72 48 -  @  ,  D  V  Z  =  -
                                0xFF, 0xFF, 0x47, 0xFF, 0x05, 0x73, 0xFF, 0xFF,  //  80 50 -  -  \  -  H  /  -  -
                                0xFF, 0x10, 0x20, 0x23, 0xFF, 0x63, 0xFF, 0xFF,  //  88 58 -  ПС ВК :  -  .  -  -
                                0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x30, 0xFF,  //  96 60 -  -  -  -  -  -  ЗБ -
                                0xFF, 0xFF, 0xFF, 0x40, 0x01, 0xFF, 0xFF, 0xFF,  // 104 68 -  -  -  <  HM -  -  -
                                0xFF, 0xFF, 0x70, 0xFF, 0x60, 0x50, 0x21, 0xFF,  // 112 70 -  -  v  -  >  ^  А2 -
                                0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x11, 0xFF, 0xFF   // 120 78 -  -  -  -  -  СТ -  -
    void setup() {
      pinMode(SS, OUTPUT); //SS
      pinMode(US, OUTPUT);  //US
      pinMode(RUS, OUTPUT); //RUS
      pinMode(IRUS, INPUT_PULLUP); //индикатор RUS
      pinMode(VVD, OUTPUT); //ВВОД
      pinMode(SBR, OUTPUT); //СБРОС
      OldRUS = digitalRead(IRUS);
      ps2Keyboard.begin();
      ps2Keyboard.awaitStartup();
      if ( OldRUS == HIGH ) {
        ps2Keyboard.sendLedStatus(ps2::KeyboardLeds::numLock);
        lastLedSent = ps2::KeyboardLeds::numLock;
      else {
        ps2Keyboard.sendLedStatus(ps2::KeyboardLeds::numLock | ps2::KeyboardLeds::scrollLock);
        lastLedSent == (ps2::KeyboardLeds::numLock | ps2::KeyboardLeds::scrollLock);
      digitalWrite(SS, HIGH);
      digitalWrite(US, HIGH);
      digitalWrite(RUS, HIGH);
      digitalWrite(VVD, HIGH);
      digitalWrite(SBR, HIGH);
      SetAddr(0);
      digitalWrite(STBMT, LOW); //инициализация
      digitalWrite(AX0, bitRead(addr, 0));
      digitalWrite(AX1, bitRead(addr, 1));
      digitalWrite(AX2, bitRead(addr, 2));
      digitalWrite(AX3, bitRead(addr, 3));
      digitalWrite(AY0, bitRead(addr, 4));
      digitalWrite(AY1, bitRead(addr, 5));
      digitalWrite(AY2, bitRead(addr, 6));
    void SetKey(boolean data) {
    void loop()
      //чтение кода
      ps2::KeyboardOutput scanCode = ps2Keyboard.readScanCode();
      if ( scanCode != ps2::KeyboardOutput::none ) {
        switch (scanCode) {
          case ps2::KeyboardOutput::unmake: {             //если считался префикс 0xF0 (отпускание клавиши)
              d = LOW;
              break;
          case ps2::KeyboardOutput::extend: {             //если считался префикс 0xE0 -- игнорим
              extkey = HIGH;
              break;
          case ps2::KeyboardOutput::sc2_leftShift: {      //если считался код 0x12 SS (Shift)
              if ( extkey == LOW) { // если был код с префиксом 0xE0, то игнорируем нажатие
                digitalWrite(SS, !d);
              extkey = LOW;
              d = HIGH;
              break;
          case ps2::KeyboardOutput::sc2_leftCtrl: {       //если считался код 0x14 RUS (Ctrl)
              digitalWrite(RUS, !d);
              d = HIGH;
              extkey = LOW;
              break;
          case ps2::KeyboardOutput::sc2_capsLock: {       //если считался код 0x58 US (CapsLock)
              digitalWrite(US, !d);
              d = HIGH;
              break;
          case ps2::KeyboardOutput::sc2_f11: {            //если считался код 0x78 VVD (F11)
              digitalWrite(VVD, !d);
          case ps2::KeyboardOutput::sc2_f12: {            //если считался код 0x07 SBR (F12)
              digitalWrite(SBR, !d);
              d = HIGH;
              break;
          default: {
              byte c = (byte)scanCode;
              if ( c < 128 ) {    // скан-код может быть больше!
                if ( table[c] != 0xFF ) {
                  SetAddr(table[c]);
                  SetKey(d);
              extkey = LOW;
              d = HIGH;
      else {
        if (digitalRead(IRUS) == LOW) { //проверяем состояние индикатора РУС
            OldRUS = LOW;
        else {
          if ( OldRUS == LOW ) {
            lastLedSent == ps2::KeyboardLeds::numLock;
            OldRUS = HIGH;
    Подключение к Вектору:
    J2 -- порт PB
    J3 -- порт PA
    J1:4 -- PC5 (кнопка СС)
    J1:1 -- PC6 (кнопка УС)
    J1:3 -- PC7 (кнопка РУС)
    H2:TX -- сигнал ВВОД
    H2:RX -- сигнал СБРОС
    Сигнал индикатора РУС следует подпаять к выводу 27 чипа ATMEGA168 на плате. Удобнее было бы использовать выводы под кварц, но они что-то не заработали...
    Важный момент: для нормальной работы клавиатуры требуется подтяжка линий порта РВ (резисторы R35..R42, RP43) и установка диодов (VD3..VD8, VD12, VD13) в линии порта РА в соответствии со схемой клавиатуры Вектора.
    Фото
    Последний раз редактировалось Improver; 03.06.2024 в 09:51. Причина: исправления в скетче
    Этот пользователь поблагодарил Improver за это полезное сообщение:
    Xrust(28.05.2024)
  1. Ответов: 34
    Последнее: 24.11.2022, 16:05
  2. Ответов: 40
    Последнее: 27.06.2021, 15:41
  3. Ответов: 146
    Последнее: 31.05.2020, 19:00
  4. Ответов: 29
    Последнее: 24.03.2019, 18:11
