PMI: KDJ11-BF, MSV11-JE
VT220, CM7209
А именно тесты из этого сообщения
"http://zx.pk.ru/showpost.php?p=567532&postcount=249
описание тестов PORT - для ДВК и PORT2 для УК-НЦ )"
Код:Image : 54y_HX22_TESTUK.dsk Format : DSK Size : 800 Kb Volume ID: RT11A Owner : File Blocks Date Bytes ---------- ------ ----------- ---------- SWAP .SYS 27P 19-Dec-1988 13'824 RT11SJ.SYS 78P 16-Dec-2012 39'936 TT .SYS 2P 23-Jan-1980 1'024 STARTS.COM 1 11-Jan-2013 512 RESORC.SAV 25 01-Mar-2012 12'800 IND .SAV 58 18-Jan-1988 29'696 DUP .SAV 45 27-Dec-1983 23'040 LD .SYS 8P 18-Jan-1988 4'096 DAY .SAV 4 19-Dec-2012 2'048 SPAM .MAC 4 09-Jan-2013 2'048 WD .SYS 3P 05-Aug-1979 1'536 WE .SYS 2P 16-May-1979 1'024 COLS .SAV 17 09-Aug-1990 8'704 WDR .SAV 3 01-Oct-1980 1'536 RUS .SAV 2 16-Oct-1994 1'024 SYS .SAV 3 30-May-1979 1'536 LAT .SAV 2 16-Oct-1994 1'024 TTY .SAV 3 25-Jan-1991 1'536 NYS .SAV 22 22-Oct-1993 11'264 PMEM .SAV 2 25-Aug-1993 1'024 TUK .SAV 35 27-Mar-1980 17'920 TS .SAV 40 31-Jul-1992 20'480 SKY .SAV 4 08-Apr-1993 2'048 MZFORM.SAV 6 13-Jun-1990 3'072 CAT .SAV 52 01-Sep-1992 26'624 HUST .SAV 6 31-Dec-1999 3'072 FONTUK.SAV 5 31-Dec-1999 2'560 AC .SYS 5P 12-Sep-1994 2'560 MZ .SYS 4P 12-Jan-1990 2'048 PIP .SAV 30 31-Oct-1998 15'360 DESS19.SAV 19 04-Mar-1994 9'728 MACRO .SAV 63 21-Dec-2012 32'256 LINK .SAV 59 31-Oct-1998 30'208 SYSMAC.SML 92 31-Oct-1998 47'104 DIR .SAV 20 31-Oct-1998 10'240 DISASM.SAV 8 07-Dec-2011 4'096 SL .SYS 10 19-Jan-1988 5'120 UCL .SAV 2 31-Dec-1999 1'024 KLAV .SAV 18 10-Feb-1989 9'216 RMKOI8.SAV 6 31-Dec-1999 3'072 RDWR .SAV 3 20-Dec-1991 1'536 TSSPD .SAV 23 25-Apr-1980 11'776 SYSLIB.OBJ 47 19-Dec-1988 24'064 SPAM .SAV 2 31-Dec-1999 1'024 TSSPD .MAC 93 11-Jan-2013 47'616 BINCOM.SAV 25 31-Oct-1998 12'800 BOT .COM 1 11-Jan-2013 512 BOTHX0.MAC 10 11-Jan-2013 5'120 C2 .COM 1 09-Jan-2013 512 C2 .MAC 5 11-Jan-2013 2'560 HX .COM 1 17-Nov-2012 512 HX .MAC 28 11-Jan-2013 14'336 C2 .LST 13 31-Dec-1999 6'656 HX .LST 73 31-Dec-1999 37'376 HX .SYG 4 31-Dec-1999 2'048 BOTHX0.LST 27 31-Dec-1999 13'824 BOTHX0.BIN 1 31-Dec-1999 512 C2 .SYS 2 31-Dec-1999 1'024 HX .SYS 4 31-Dec-1999 2'048 PALSW .SAV 23 11'776 PORT .MAC 12 14-Jan-2013 6'144 PORT .SAV 16 14-Jan-2013 8'192 PORT2 .SAV 16 14-Jan-2013 8'192 < UNUSED > 361 184'832 ---------- ------ ----------- ---------- 63 Files, 1225 Blocks 361 Free blocks "http://zx.pk.ru/showpost.php?p=567532&postcount=249 описание тестов PORT - для ДВК и PORT2 для УК-НЦ )"
Испытал PCI-Serial плату OX16PCI952 производства Oxford Semiconductors Ltd. Могу сказать, что результаты положительные. Загрузка происходила с включенным сжатием. Команды DIR/BAD/FIL и COP/DEV HX1: HX7: выполнены успешно. Во время чтения выходил в пультовый режим и смотрел регистр 176570, все отлично - бита переполнения не установлено.
А если PORT.SAV и PORT2.SAV запустить - какие результаты выводит ?
Так собственно уже давно ответил.
---------- Post added at 21:38 ---------- Previous post was at 20:10 ----------
Испытал VSCom uPCI-200L. Вообще не пошло. На некоторых настройках PC вместо одного байта "@" получает почему-то два - "@" как надо и байт с кодом ноль. Когда получение "@" проходит нормально, то передается несколько байт первичного загрузчика и на этом все замирает.
Именно так было и в начале тестирования:
В приложении - тестовая версия Boot_RT-11_from_HX0.bin, выводящая эхо на экран при приёме каждого байта из порта С2. Если вывод на экран УКНЦ не упирается в конце строки - можно оценить число принятых байтов.
