Показано с 1 по 10 из 19
Тема: Pentagon 128k debugging
    Berlin, Germany
    47
    31 сообщений
    По умолчанию Pentagon 128k debugging
    Hi there,
    I'm currently in the progress of building a Pentagon 128 (Revision 2011 produced by zorel). Good things first, it already boots, accepts keyboard input and even lists betadisk directories. Now comes the bad part, after a few seconds I get junk characters on the screen, but the machine remains operational for a few more seconds til it crashes (mostly after 30-45 seconds). Sometimes it reboots, but most of the time it just hangs requiring a hard reset. Any ideas what could be wrong?
    Further info:
    - IC type is all 74lsxxx except for dd02, dd11 & dd12 (used 74hct93 there). I used the translation table from here: http://sblive.narod.ru/ZX-Spectrum/P...ntagon128k.htm (except for dd100 which is wrong there and should be cd4069).
    - RAM chips are 41256 and have decoupling capacitors
    - random decoupling capacitors have been placed on the board
    - resistor and capacitor values have been used according to pentagon.pdf from here http://zxspectrum.it.omegahg.com/doc/Pentagon.pdf
    Here's also a picture:
    http://img855.imageshack_.us/img855/...ntagon128k.jpg
    So any ideas what to try next?
    Pentagon 48 + MIKAY128 + VG93 Turbo + Stereo Covox + KJoy
    Москва 128 + AY
    Pentagon 1024SL 2.2 + ZXM-GS + Z-Controller + TSFM + Tape-In
    ZX Evolution Rev. C + ZX-MultiSound
    Compact 256 Turbo 1.1 (ZS Scorpion 256 INT, Port #FF, Port #FB) + Covox + ProfROM + NemoBus + NemoIDE + ZXM-GS
    ZS Scorpion 256 Turbo+ + GMX + SMUC + GS Classic 2MB
    Sprinter 2016S
    К сожалению, я не говорю по-русски / Sorry, I don't speak Russian
    https://github.com/zxshock
    г. Красноярск
    129
    104 сообщений
    Are all the errors of the board have been eliminated?
    http://zx.pk.ru/showpost.php?p=535392&postcount=371
    Is the board AY \ YM, it also is an error.
    Последний раз редактировалось null_device; 10.02.2013 в 02:42.
    Berlin, Germany
    47
    31 сообщений
    Thanks for letting me know about that one - didn't know about that one before, fixed that, didn't help much
    I've also fixed the missing track on dd31 and added R50 (56kohm)
    Москва 128 + AY
    Sprinter 2016S
    г. Красноярск
    129
    104 сообщений
    Sorry if this mу advice does not help.
    In the next branch, discussed the assembly and adjustment of the board, try to ask a question there.
    http://zx.pk.ru/showpost.php?p=574471&postcount=983
    Berlin, Germany
    47
    31 сообщений
    Just to let you guys know: both of my Pentagons are up and running
    Appears the first one was suffering from a flakey PSU (I was using my PC's) and C7 being soldered in the wrong place and the second one must have had a cold solderjoint, as it magically started working once I re-soldered every chip.
    So ... what are good measures for testing that everything is working alright?
    I've tried loading and running a demo from disk (Alienate by Hooy-Program), loading and saving a program from/to tape, testing the INT and RAM using Test 4.30 (which also confirms the tact at 171680 cycles).
    One more thing that comes to my mind would be testing a demo that uses covox sound and that would be pretty much all.
    Москва 128 + AY
    Sprinter 2016S
    379
    242 сообщений
    How many INT cycles? "Too short", "Too long" or..?
    If you connect DAC (R-2R or 8bit chip) on "printer port"... only after that you can hear covox sound.
    Profi must live!
    Моё железо...
    Все укомплектованы:
    Berlin, Germany
    47
    31 сообщений
    Test 4.30 gives me 32-28
    TestInt reports 40-36
    Hidden part of the Insult Megademo shows just fine.
    Москва 128 + AY
    Sprinter 2016S
    379
    242 сообщений
    there are no more questions) pentagon work properly. my congratulations!!!
    Profi must live!
    Моё железо...
    Все укомплектованы:
    119
    80 сообщений
    он жаловался на то что все работает, выводит каталог диска, но через несколько секунд появляются случайные символы и затем через 30 сек крешится..
    379
    242 сообщений
    где? этот баг кажись устранен давно. он вроде отписался, что всё работает замечательно и он погонял разные тесты, демы и т.д....
    Profi must live!
    Моё железо...
    Все укомплектованы:
  1. Как быть с реалом - Pentagon 128k ?
    от dM_GBG в разделе Pentagon
    Ответов: 49
    Последнее: 14.01.2021, 18:05
  2. куплю pentagon 128k
    от ZX1997 в разделе Барахолка (архив)
    Последнее: 12.01.2012, 14:41
  3. Помогите с Pentagon-128k !
    от r0m в разделе Pentagon
    Ответов: 383
    Последнее: 15.05.2010, 02:51
  4. Ответов: 57
    Последнее: 03.04.2010, 07:42
  5. Ответов: 0
    Последнее: 24.01.2010, 21:46
