Вместе с памятью пришли так же две весьма полезные для создания стендов платы - 4-портовые серийникиОдна оказалась DEC-овский - консольный порт точно работает, вторая с правильными джамперами (а не проволочками, как любит DEC), но не DEC-овская, так что с документацией туго... не нашёл пока
Плюс 4 кб памяти
- - - Добавлено - - -Код:.SHO ALL RT-11SB V05.07 Booted from DU0:RT11SB USR is set SWAP EXIT is set SWAP KMON is set NOIND MODE is set NOSJ TT is set NOQUIET ERROR is set ERROR SL is set OFF EDIT is set KED FORTRAN is set FORTRA KMON nesting depth is 3 CLI is set DCL, CCL, UCL, NO UCF LSI 11 or PDP 11/03 Processor 60KB of memory Extended Instruction Set (EIS) Floating Instruction Set (FIS) 60 Hertz System Clock FPU support Device Status CSR Vector(s) ------ ------ --- --------- DL Not installed 174400 160 DM Not installed 177440 210 DU Resident 172150 154 DW Not installed 000000 DX Not installed 177170 264 DY Not installed 177170 264 DZ Not installed 000000 RK Not installed 177400 220 LD Installed 000000 000 LP Not installed 177514 200 LS Installed 176500 470 474 300 304 MM Not installed 172440 224 MS Not installed 172522 224 300 MT Not installed 172520 224 MU Not installed 174500 260 NL Installed 000000 000 PI Not installed 000000 000 SL Installed 000000 000 SP Installed 000000 110 VM Not installed 177572 250 XC Not installed 173300 210 214 XL Installed 176500 300 304 HX Installed 177560 000 ZA Installed 161014 350 ZB Installed 161054 354 ZC Installed 161114 360 ZD Installed 161154 364 ZE Installed 161214 370 ZF Installed 161254 374 WS Not installed 177134 204 WQ Not installed 177134 204 TT (Resident) DU (Resident) DU0 = DK , SY LD SL HX ZA ZB ZC ZD ZE ZF SP XL LS NL 7 free slots Job Name Console Level State Low High Impure --- ---- ------- ----- ----- --- ---- ------ 0 RESORC 0 0 Run 000000 144326 146032 No multi-terminal support Address Module Words ------- ------ ----- 170000 IOPAGE 2048. 164060 DU 1000. 144372 RMON 3995. 001000 ..BG.. 25469. No LD units mounted .
Проц с ДП с этой же платой памяти
Вот уже становится интересным - эти 4 кб памяти - не вызовут ли они сбои в ПО, ибо видны как бы дважды с ДП - в составе 64 кб памяти и ещё раз на странице в/в...Код:.SHO CONF RT-11SB V05.07 Booted from DU0:RT11SB USR is set SWAP EXIT is set SWAP KMON is set NOIND MODE is set NOSJ TT is set NOQUIET ERROR is set ERROR SL is set OFF EDIT is set KED FORTRAN is set FORTRA KMON nesting depth is 3 CLI is set DCL, CCL, UCL, NO UCF PDP 11/23 Processor 64KB of memory FP11 Hardware Floating Point Unit Extended Instruction Set (EIS) Memory Management Unit 60 Hertz System Clock FPU support .SHO MEM Address Module Words ------- ------ ----- 170000 IOPAGE 2048. 164060 DU 1000. 144372 RMON 3995. 001000 ..BG.. 25469. .
Попробовал поиграться с М6 в корзине DEC. Есть проблема - при попытке работать с контроллером DU - зависание. Причём зависание идёт даже при попытке загрузить в основную память консоль CMD. То есть наблюдается проблема с ПДП
Аналогично попробовал поиграться с М8 (проц, правда, J11, а не 1831) - бест проблем, грузанулся вполне норм с DU
Память показывает как и KDF11-A (наш аналог - М6) - 60 кб доступно, 64 - всего
Распределение памяти с этой платой памяти под XM монитором
То есть XM монитор не стал использовать добавок памяти на странице в/в в принципе.Код:.sho mem ------- Extended Memory -------- Address Module Words Type ------- ------ ----- ---- 17760000 IOPAGE 4096. PRM HDW BYP 00200000 MEMTOP 00172100 ...... 1504. 00165000 DU 1312. PVT 00160000 MCA 1280. PRM 00000000 KERNEL 28672. PRM HDW ------ Low Memory ------- Address Module Words ------- ------ ----- 157314 DU 154. 116702 RMON 8325. 104640 USR 2577. 001000 ..BG.. 17360. .
Ишо на KDF11-A вытащил ДП и загрузил SB. Ну, ничего не ожиданного - 60 кб, как и на LSI-11
Всё, на вторую четырёх портовку тоже нашёл доки и запустил![]()
Ответить с цитированием
