Страница 74 из 224 ПерваяПервая ... 707172737475767778 ... ПоследняяПоследняя
Показано с 731 по 740 из 2231
Тема: ZXMAK2 - Виртуальная машина ZX Spectrum
  1. #731
    Biała Podlaska
    WinXP SP2 have DirectX 9.0c default. ZXMAK2 need other update to fix the problem:
    directx_Jun2010_redist
    Is VI53 sound emulation working in "Byte"?
    I have suggestion. Please increase BORDER top and bottom in windowed 100%. Border size is not the same and it looks ugly.
    P.S. Sound emulation VI53 working in other emulator b2m but playing is too fast
    http://zx-pk.ru/showthread.php?t=20158&page=3
    Последний раз редактировалось Gelip; 07.05.2013 в 11:02.
  2. #732
    119
    80 сообщений
    Цитата Сообщение от Moro Посмотреть сообщение
    Выбирается BYTE 128K + TRDOS, но в TRDOS не перезагружается :-(
    Сброс всегда идет обычный, т.е. эмулируется контроллер дисковода с перемычкой обычного сброса
    Цитата Сообщение от Gelip Посмотреть сообщение
    Hi. I have problem to run ZXMAK2 in Windows XP SP2:
    This is because some components of the DirectX 9 is missing from your system. Just run the DirectX 9 Redistributable web installer and it will check, download and install all required components. The web installer is available on microsoft web site: http://www.microsoft.com/en-us/downl...ils.aspx?id=35
    ---------- Post added at 23:48 ---------- Previous post was at 23:38 ----------
    no, VI53 is not implemented yet.
    But memory emulation (with ROM remap feature) and ULA emulation (with multicolor and slow memory) is done.
    Also you need to disable tape traps and autoplay on the tape window to pass Tserikopik protection
  3. #733
    Biała Podlaska
    Yes it's working but I found one problem:
    1. Open Tape window
    2. Click anywhere in main window program e.g. menu File
    3. Now if you click icon Use Trap or Use Auto Play in Tape window this not switch on button
    4. Only when you click second time the same icon - button is switched
    For this reason, I had trouble loading the game with Cerikopik :-)
  4. #734
    Александр, не могли бы Вы осветить еще один вопрос? Посмотрел в эмуляторе список подключенного оборудования и нашел там "Tape recorder". Это что за зверь такой? Попробовал сделать SAVE "dfdfd" - полоски бегут, нравится, а откуда потом грузить это "dfdfd"? Идея была в том, чтобы выгрузить на реальны спек загруженное в эмулятор В исходниках не рылся, на удачу спрошу: насколько трудоемко будет прикрутить в качестве магнитофонного порта, скажем, парочку линий LPT или COM1? Или еще какого аппаратного порта на Ваш выбор? Спасибо
    П.С. Или такая функция уже имеется, просто я, как обычно, изобретаю очередной велосипед?
    Последний раз редактировалось Abadonna; 26.04.2013 в 18:25.
  5. #735
    ZEK
    Звуковуха, не?
  6. #736
    г. Рязань
    124
    44 сообщений
    Alexander Makeev, хочется еще одно пожелание: заимпрувить FormMachineSettings.initConfig() и BusManager.LoadConfig() так, чтобы при смене конфига через Wizard либо существующие и в старом, и в новом конфиге девайсы не пересоздавались, либо при пересоздании переносились сеттинги. Что конкретно хочется - чтобы из BDI не высовывались дискеты при смене одной машины с дисководом на другую. Надо при отладке мультиколоров под разные клоны.
    P.S. ZXMAK - лучший эмуль с точки зрения точности эмуляции ULA (да и еще много в чем). Спасибо тебе огромное за него!
  7. #736
  8. #737
    119
    80 сообщений
    не "Tape recorder",а "Tape player", он только проигрывать умеет
    а зачем? Записываешь касету в WAV файл и открываешь потом WAV файл эмулятором...
    ---------- Post added at 01:16 ---------- Previous post was at 01:10 ----------
    девайсы и так не пересоздаются - если тип девайса такой-же, то используется экземпляр девайса от предыдущей конфигурации. За счет этого можно поменять ULA, но память при этом не очистится
    В BDI дискеты высовываются чтобы если на них была запись, не потерять записанное. При высовывании дискеты происходит выгрузка изменений из памяти на диск.
    ---------- Post added at 01:23 ---------- Previous post was at 01:16 ----------
    спасибо но в некоторых ULA еще есть небольшие баги с отображением (например бордер на spectrum +2A/+3), ими я и планирую заняться в ближайшее время
    Последний раз редактировалось ZXMAK; 27.04.2013 в 02:18.
  9. #738
    г. Рязань
    124
    44 сообщений
    Нда, не доковырял сырцы. Я посмотрел, что все они от шины отваливаются, думал, и убиваются заодно.
    Может, не стоит их совсем высовывать? Ну или всовывать обратно при запуске новой конфигурации...
  10. #739
    Да, точно, плеер, а не рекордер. Наоборот, у меня была идея перенести из эмулятора в реал. На РС много спековского софта, а вынести наружу его не всегда удается Вот и подумал, авось так получится
  11. #740
    119
    80 сообщений
    Запись tap файлов - это конечно очень полезная фича, но требует наработки соответствующих алгоритмов для детекции начала/конца записи и т.п.
    Сейчас у меня более приоритетные задачи - доработать расчет таблиц для рендеринга, отрефакторить движок, добавить новые отладочные фичи (останов по доступу к ячейке памяти/порту и т.п.), переписать отладчик (код которого написан еще в 2001 году и рефакторингу с того времени не подвергался)
  1. Ответов: 7
    Последнее: 06.04.2012, 21:37
  2. Машина Тьюринга для Z80
    от ZXMAK в разделе Эмуляторы
    Последнее: 15.08.2011, 03:26
  3. Продвинутая Мелко Машина 1
    от Black_Cat в разделе Зарубежные компьютеры
    Ответов: 74
    Последнее: 03.03.2009, 09:05
  4. Что за машина такая??? Commodore 128...
    от ILoveSpeccy в разделе Commodore 16/64/128
    Последнее: 31.10.2007, 10:25
  5. Java-машина
    от Error404 в разделе Программирование
    Последнее: 15.01.2007, 15:11
