Страница 4 из 8 ПерваяПервая 12345678 ПоследняяПоследняя
Показано с 31 по 40 из 71
Тема: Лечим ZX Spectrum +2 (Grey)
  1. #31
    85
    50 сообщений
    ок ) пока не послушаю, ничего предпринимать не буду ) услышать бы его...
  2. #31
  3. #32
    85
    50 сообщений
    Господа, я сдаюсь. 12 вольт нету. Где потерялись, хз. Трансформатор т1 сдох? Куда тестером потыкать, чтобы понять?
  4. #33
    1,459
    949 сообщений
    вот описание работы всего узла
    It is esentially an inverter circuit. TR5, TR4 and the coil forms the inverter. It generates a pulsating 12V signal at the collector pin of TR4 (it comes from the reactance discharging through transistor TR4). That signal is AC coupled by C80, so we have something similar to a 12V AC power supply, of about 110kHz, at the right side of C80.
    D15, D17 and C44 form a simple rectifier and a simple filter. As frequency is much higher than 50Hz, no full rectifier or big capacitors are needed in order to have a steady power supply. The junction at D15 and C44 carries a 12V DC signal suitable for DRAM chips.
    The same voltage is passed through a PI filter formed by C44, R62 and C45 to give another 12V supply rail, isolated from the first one. This isolation (achieved in some way because of the PI filter) is needed to avoid high frequency switching noise coming from DRAM chips to enter the video circuit section, which would make it to display on screen, degrading picture quality.
    To generate -5V, a similar circuit is used: from the same point the 12V supply is got, another capacitor, C46, gives a 12V AC signal. Diodes D11, D18 and capacitor C79 play a similar role to D15, D17 and C44. Only that this time, diodes are arranged in the opposite direction, so the output signal is negative (with respect to ground). D19 is a 5.1 zener diode, which is used to lower the voltage from -12V to -5V. In order to not to destroy the zener, a current limiting resistor R79 is used. The -5V supply is very weak and only used to polarize the substrate of DRAM chips.
  5. #34
    г. Воткинск
    36
    27 сообщений
    Я сразу хотел предложить проверить 12В, вы в какую-то канитель упёрлись... Проверять транзистор, я менял.
    Я сразу хотел предложить проверить 12В, вы в какую-то канитель упёрлись... Проверять транзистор TR9, я менял.
    Karabas Pro Rev.E / MiST 1.31 / ZX-Evolution (Rev.C4 + VDAC2 + ZiFi) / ZX Spectrum 128K +2B / DivGMX / ReVerSE-U16 (EP4CE22+16M16+TS-Conf) / Пентагон-128К (2014) PS/2, NemoIDE / Компаньон-2 (1994)
  6. #35
    85
    50 сообщений
    В какую канитель я уперся? Сразу 12в искал. Спасибо за наводку на транзистор.
  7. #36
    г. Екатеринбург
    34
    29 сообщений
    Подключитесь по RGB к телеку и забудьте про эти 12 вольт, преобразователь 7805 выкиньте, на плату подавайте сразу 5 вольт и будет вам счастье.
    Моё железо
    ZX Spectrum +2
    ZX Spectrum +3
    Harlequin 48K
    Harlequin 128K
    Karabas-128
    85
    50 сообщений
    NiKa, я уже говорил, что один из моих теликов не имеет скарта.
  9. #38
    г. Екатеринбург
    34
    29 сообщений
    Да но композитный сигнал на всех Амстрадах отвратительный, что там не делай все равно будет либо плохо, либо очень плохо, у простого 48к с этим намного лучше.
    Моё железо
    ZX Spectrum +2
    ZX Spectrum +3
    Harlequin 48K
    Harlequin 128K
    Karabas-128
    85
    50 сообщений
    NiKa, вы мне это все зачем говорите?
    А по сабжу - пока не дошли руки проверить транзисторы по питанию.
  11. #40
    Novosibirsk
    9 сообщений
    1) преобразователь там простой как лом. Не вижу проблемы его ремонтировать.
    2) если ампутировать преобразователь то можно угореть на ремонт фирменной периферии. Потому-что она кормится с краевого разьема и -5 и +12. И если ей надо три напруги, то с большой вероятностью она отправится на небеса. Кроме того туда еще и 9 вольт заведено. Так что периферия у которой есть на борту свой преобразователь тоже не заведется, и последствия могут быть ровно теми же самыми.
  1. ZX Spectrum +2 grey model + BDI + LG 15LC1R
    от drbars в разделе Зарубежные модели
    Последнее: 29.06.2014, 20:42
  2. ZX Spectrum +2 grey model + VGA Convertor + NEC 1560NX
    Последнее: 10.05.2014, 20:51
  3. Ответов: 7
    Последнее: 06.04.2012, 21:37
  4. Владельцам ZX Spectrum+128 и ZX Spectrum+2(grey)
    от Black_Cat в разделе Зарубежные модели
    Последнее: 11.03.2012, 17:24
  5. H.B. Jedius, Robus, Grey
    от Conan в разделе Поздравления
    Последнее: 28.09.2005, 22:53
