.SH ALL
TSX-Plus Version = 6.50
19-Mar-2015
Active Handler Handler Handler
Device I/O Status V. base P. base size CSR Vector
TT 0 000004
LD 0 102446
CL 0 016057 061550 000000 512
DU 0 102450 112566 000000 340
MU 0 017060 113312 000000 410
EQ 3 007061 120000 073370 3528
LP 0 030003 120000 072371 406
NL 0 000025 120000 072370 60
VM 0 102447 114144 000000 426
Assignments:
SY --> DU2:
TCP --> LD7:
CF --> VM0:
WF --> VM0:
DK --> LD6:
Device Job Job name
CL0 18 TCP/IP
Uptime: 01:16:25
System use: Run=0%, I/O-wait=99%, Swap-wait=0%, Idle=0%
I/O Activity: User I/O=99%, Swapping I/O=0%
Job Line Pri State Size Connect CPU time Program Job name
1 1(0) 40 TI 39Kb 01:17:00 00:00:02 KMON
10 10(0) 40 TI 39Kb 00:07:00 00:00:01 KMON ROOT
11 11(0) 40 TI 39Kb 00:01:00 00:00:01 KMON GUEST
18 Det. 50 HI 63Kb 00:07:00 00:00:04 RTELNT TCP/IP
19 Det. 50 SL-Swap 33Kb 01:17:00 00:00:00 WINPRT Window print
20 Det. 50 SL 63Kb 01:17:00 00:00:00 RTSORT SYSTEM
21 Det. 50 SL-Lock 63Kb 01:17:00 00:00:19 TCPIP TCP/IP
26 10(1) 40 TI 39Kb 00:07:00 00:00:00 KMON ROOT
27 10(2) 40 TI 39Kb 00:06:00 00:00:00 KMON ROOT
28 10(3) 50 TI 39Kb 00:06:00 00:00:01 KMON ROOT
29 1(1) 40 TI 39Kb 00:04:00 00:00:00 KMON
30 1(2) 40 TI 39Kb 00:04:00 00:00:00 KMON
31 1(3) 50 SL 39Kb 00:04:00 00:00:04 $HOST$
32 11(1) 40 TI 39Kb 00:01:00 00:00:00 KMON GUEST
33 11(2) 40 TI 39Kb 00:01:00 00:00:00 KMON GUEST
34* 11(3) 50 IN 39Kb 00:01:00 00:00:02 KMON GUEST
ine Type Vector CSR Terminal Speed Active Line Name
1 Oper. DL 060 177560 VT200 9600 8N Yes Console
2 Local DL 300 176500 VT200 9600 8N No DLV11 - 1
3 Local DL 310 176510 VT200 9600 8N No DLV11 - 2
4 Local DL 320 176520 VT200 9600 8N No DLV11 - 3
5 Local DL 330 176530 VT200 9600 8N No DLV11 - 4
6 Local DHV- 0 360 160500 VT200 Auto 8N No DHV11 - 0
7 Local DHV- 1 360 160500 VT200 Auto 8N No DHV11 - 1
8 Local DHV- 2 360 160500 VT200 Auto 8N No DHV11 - 2
9 Local DHV- 3 360 160500 VT200 Auto 8N No DHV11 - 3
10 Local DHV- 4 360 160500 VT200 9600 8N Yes DHV11 - 4
11* Local DHV- 5 360 160500 VT200 9600 8N Yes DHV11 - 5
12 Local DHV- 6 360 160500 VT200 9600 8N CL0 DHV11 - 6
13 Local DHV- 7 360 160500 VT200 9600 8N CL1 DHV11 - 7
14 Local DZ - 0 350 160100 VT200 9600 8N No DZQ11 - 0
15 Local DZ - 1 350 160100 VT200 9600 8N No DZQ11 - 1
16 Local DZ - 2 350 160100 VT200 9600 8N No DZQ11 - 2
17 Local DZ - 3 350 160100 VT200 9600 8N No DZQ11 - 3
CL version number 18.
Unit Line Job Options
CL0 12 18 [FORM,TAB,LC,LFOUT,LFIN,CR,CTRL,DTR]
CL1 13 1 [LC,LFOUT,LFIN,CR,CTRL,DTR]
CL2 none none
CL3 none none
Total installed memory = 4088Kb
Size of unmapped TSX and handlers = 39Kb (115252)
Size of mapped TSX system regions = 81Kb
Total size of TSX and mapped data = 142Kb
Size of mapped device handlers = 4Kb
Size of sharable run-time systems = 54Kb
Size of data cache buffer area = 0Kb
Space available for user jobs = 1806Kb
Swappable job context area = 7Kb
Current job memory limit = 56Kb
Maximum job memory limit = 64Kb
QUAN0 = 2
QUAN1 = 20
QUAN1A = 2
QUAN1B = 2
QUAN1C = 1
QUAN2 = 10
QUAN3 = 20
INTIOC = 30
HIPRCT = 40
Spooled devices: LP0
Logical subset disks:
LD6 --> DU2:TSXWRK.DSK[10240]
LD7 --> DU2:TSXTCP.DSK[4800] (read only)
Mounted devices:
Device Associated jobs
DU2: 1 10 11 26 27 28 29 30 31 32 33 34
DU2:TSXTCP 1 10 11 18 21 26 27 28 29 30 31 32 33 34
DU2:TSXWRK 1 10 11 26 27 28 29 30 31 32 33 34
VM0: 1 10 11 26 27 28 29 30 31 32 33 34
Shared run-time systems:
CBR063
Region Size Type Job Use Shared AGE Base
WIN01A 3.8 Global 1 1 No No 072170
SCKT00 8.0 Global 21 2 Yes No 071770
WIN10A 3.8 Global 10 1 No No 071670
WIN26A 3.8 Global 26 1 No No 071570
WIN27A 3.8 Global 27 1 No No 071470
WIN28A 3.8 Global 28 1 No No 071370
WIN29A 3.8 Global 29 1 No No 071270
WIN30A 3.8 Global 30 1 No No 071170
WIN31A 3.8 Global 31 1 No No 071070
WIN11A 3.8 Global 11 1 No No 070770
WIN32A 3.8 Global 32 1 No No 070670
WIN33A 3.8 Global 33 1 No No 070570
WIN34A 3.8 Global 34 1 No No 070470
Authorized privileges: ALLOCATE,DEBUG,DETACH,MESSAGE,NFSREAD,NFSWRITE,
RLOCK,SEND,SETNAME,SPFUN,SYSGBL,SAME,SUBPROCESS
Current privileges: ALLOCATE,DEBUG,DETACH,MESSAGE,NFSREAD,NFSWRITE,
SL status: ON,NOKED,NOTTYIN,SUBSTITUTE
VM Base=100000 Top=170000 Size=3584
